fuel light
i got a 98 civic dx and i never seen my low fuel light come on could this b a fuse or did the bulb burn out where in the car could i look for the problem? thanks
RE: fuel light
I have a 93 DX and I dont have a fuel light.
RE: fuel light
you cant remove your insterment cluster, find the wire coming from the fuel light, turn on your car (make sure you have low fuel) and use a wire tester to see if its geting juice...if not, then i dont know where to look, because i think most of the lights are all on one fuse (cluster lights that is) so all of them shouldnt work if thats the problem. also, i think thats a good thing that you havent seen that light. :Dif it is getting juice then check the bulb, you should be able to find a replace ment at radio shack (you will need to be kinda crative, find one close b/c you arnt going to have a modle numeber or anything.) or get robbed by the honda dealership, because they most likley wont sell you one bulb, just the whole thing. and its going to be expensive from them anyway.
RE: fuel light
ORIGINAL: that_guy5 i got a 98 civic dx and i never seen my low fuel light come on could this b a fuse or did the bulb burn out where in the car could i look for the problem? thanks i'll ditto this statement... i'm under the impression that either the 11.9gallons the manual says is the tank capacity is incorrect, or a general fault in the sensor in these models is the culprit i know for a fact I've put 11.7 gallons of gas in my car without the low fuel light coming on... so it either comes on when the tank is bone dry or out of gas, or it doesn't work at all, i've double checked all of my fuses, reset my ecu several times, and checked the voltage to the light, but i've yet to figure out why the sob doesn't turn on, my last thought is to replace the sensor in the tank, but i'll be damned if i've ever found one edit: wow... 400th post |
RE: fuel light
ive got a 97 lx mine works fine it comes on and i put about 9-10 gals when its on
RE: fuel light
Here's an idea, do'nt judge how much fuel you have by the light comming, or hoping the light comes on., when it says low on the gauge it is time for a gas stop ;)
RE: fuel light
thats a great idea fiirkanhow did u come up with that lol
if i tried that in my 89 hatch it would not work though it stays on above full all the time |
RE: fuel light
ORIGINAL: civicblend97 ive got a 97 lx mine works fine it comes on and i put about 9-10 gals when its on |
My 97 EX recently went below the red line a little and I filled it with 10.7 gal. and never saw a gas light
i have a 2004 civic ex and i started having a problem with my fuel gauge.It started giving me the wrong readings and i would fill my car up and the guage would only go to about half way and it change its fuel levels when i drive.As of the last 3 months it has been stuck on E with the light on and has not moved.Any ideas? would i need a new sending unit or could it be something else? is this something i can do myself? HELPPPP!!!!!!
