fuel light
Old Jan 14, 2007 | 01:49 PM
that_guy5's Avatar
Default fuel light
i got a 98 civic dx and i never seen my low fuel light come on could this b a fuse or did the bulb burn out where in the car could i look for the problem? thanks
Old Jan 14, 2007 | 02:25 PM
INJENalltheway's Avatar
Default RE: fuel light
I have a 93 DX and I dont have a fuel light.
Old Jan 17, 2007 | 11:31 AM
the_turtle's Avatar
you cant remove your insterment cluster, find the wire coming from the fuel light, turn on your car (make sure you have low fuel) and use a wire tester to see if its geting juice...if not, then i dont know where to look, because i think most of the lights are all on one fuse (cluster lights that is) so all of them shouldnt work if thats the problem. also, i think thats a good thing that you havent seen that light. if it is getting juice then check the bulb, you should be able to find a replace ment at radio shack (you will need to be kinda crative, find one close b/c you arnt going to have a modle numeber or anything.) or get robbed by the honda dealership, because they most likley wont sell you one bulb, just the whole thing. and its going to be expensive from them anyway.
Old Jan 22, 2007 | 03:52 PM
cderalow's Avatar
ORIGINAL: that_guy5
i'll ditto this statement...
i'm under the impression that either the 11.9gallons the manual says is the tank capacity is incorrect, or a general fault in the sensor in these models is the culprit
i know for a fact I've put 11.7 gallons of gas in my car without the low fuel light coming on... so it either comes on when the tank is bone dry or out of gas, or it doesn't work at all, i've double checked all of my fuses, reset my ecu several times, and checked the voltage to the light, but i've yet to figure out why the sob doesn't turn on, my last thought is to replace the sensor in the tank, but i'll be damned if i've ever found one
edit: wow... 400th post
Old Jan 23, 2007 | 01:47 PM
civicblend97's Avatar
ive got a 97 lx mine works fine it comes on and i put about 9-10 gals when its on
Old Jan 23, 2007 | 01:52 PM
Fiirkan's Avatar
Here's an idea, do'nt judge how much fuel you have by the light comming, or hoping the light comes on., when it says low on the gauge it is time for a gas stop
Old Jan 23, 2007 | 02:12 PM
thats a great idea fiirkanhow did u come up with that lol
if i tried that in my 89 hatch it would not work though it stays on above full all the time
Old Jun 1, 2007 | 10:28 AM
imsos04's Avatar
ORIGINAL: civicblend97
About where is your fuel needle when the light comes on? I'm kind of wondering if mine works on my 97 civic EX coupe and right now, the needle is almost touching the red line andthe light hasn't come on.
Old Apr 5, 2010 | 03:25 PM
bamarigs's Avatar
My 97 EX recently went below the red line a little and I filled it with 10.7 gal. and never saw a gas light
Old Apr 19, 2010 | 04:54 PM
civicsamps's Avatar
i have a 2004 civic ex and i started having a problem with my fuel gauge.It started giving me the wrong readings and i would fill my car up and the guage would only go to about half way and it change its fuel levels when i drive.As of the last 3 months it has been stuck on E with the light on and has not moved.Any ideas? would i need a new sending unit or could it be something else? is this something i can do myself? HELPPPP!!!!!!
