Fuel Rail/Injectors/Pump etc.
Old May 22, 2006 | 12:21 PM
FlipHKD720's Avatar
Default Fuel Rail/Injectors/Pump etc.
What does upgrading your fuel system actaully do? I've heard about the air/fuel mixture but i'm not really sure what it is. Does it allow for fuel to flow through your engine, and if so, shouldnt it make your gas mileage go down quite a bit?
Old May 22, 2006 | 04:39 PM
riceburner700's Avatar
Default RE: Fuel Rail/Injectors/Pump etc.
a fuel system upgrade is just like bigger injectors, larger bore on the fuel rail, high output fuel pump. It just makes it so you arnt gonna run lean and have all the fuel you need the more power you start to put down..
porkbun
Jul 18, 2007 07:31 PM
porkbun
Jul 18, 2007 08:33 AM
4doorcivic9
Jul 11, 2007 10:54 PM
nightrider46
Aug 23, 2005 03:42 PM
98brokeassvtec
Aug 23, 2004 05:31 PM
