Fueling adjustments
Old Jun 12, 2006 | 03:50 PM
pWnEdU's Avatar
Default Fueling adjustments
So can you just add larger injectors and get a adjustable fuel regulator to change the fueling on these cars? You would have the same fueling curve and timing, just more fuel...
And then if you wanted more fuel AND more timing, then injectors, adj. fuel regulator, and programming is necessary?
But according to the the FAQ's, I can't get my car reprogrammed???
Old Jun 12, 2006 | 11:27 PM
fast93civic's Avatar
Default RE: Fueling adjustments
Why do you want to add more fuel to your motor? Unless you got some heavy duty mods you dont even need to worry about more fuel. If you add larger injectors and a regulator you will run rich, and will lose power. What mods do you already have done?
Old Jun 13, 2006 | 03:29 PM
pWnEdU's Avatar
I'm not planning on moding my engine, I'm just asking for knowledge's sake.
Old Jun 14, 2006 | 12:52 AM
Then you got your answer
Old Jun 14, 2006 | 04:28 PM
pWnEdU's Avatar
Thnx
NOWAYTREY
Oct 21, 2011 07:05 PM
mysi
Aug 10, 2007 06:51 PM
killasystems
Jun 10, 2006 04:30 PM
turbo t
Jun 9, 2006 11:05 PM
pWnEdU
Jun 9, 2006 06:29 PM
