greddy turbo timer question
Old Jan 24, 2006 | 08:18 PM
riceburner700's Avatar
Default greddy turbo timer question
ok i got my turbo timer all ready to be installed and got that generic wiring diagram a while ago when one of the top posters on here put it up, now my question is that were is the IGNITION RELAY located? and also if i could just use my own relay?
Old Jan 26, 2006 | 12:21 AM
Pete's Avatar
Default RE: greddy turbo timer question
im not on my home PC but im pretty sure i have the diagram on it. Ill post in a few hrs.
Old Jan 26, 2006 | 07:14 PM
k
Old Jan 26, 2006 | 09:15 PM
Pete's Avatar
The solid white wire is 12v. The white with black stripe is ACC and the black with yellow stripe is ignition/ON. To unplug the "key harness" just remove the fuse panel. The entire panel and just unplug it from the fuse panel, it is located right below the yellow wire with yellow plug.
The yellow wire with yellow plugs are for the airbag, DO NOT cut these! If you are extremely worried about them deploying then disconnect your battery completely and then unplug the airbag plugs from the fuse box. I have done this many times and my airbags have never deployed.
Hope this helps you out. BTW It is easier to work with the wires if you remove the metal cover as well, it has two 10mm bolts, one on each side.
You should join www.turbod16.com its a verry useful site (Thats where i got that info)
FlipHKD720
Jun 9, 2007 08:41 PM
sway2003
Jan 25, 2007 05:38 PM
slowride
Sep 15, 2006 02:39 AM
97civicturbo
Feb 13, 2006 01:30 AM
Pete
Aug 28, 2005 07:19 PM
