Help figuring out ECU code, please
Old Feb 10, 2010 | 08:48 AM
cranemec's Avatar
Default Help figuring out ECU code, please
I'm working on a 1994 Civic LX, the engine will run fine for a while then starts surging. The check engine light stays on. I read here how to use the jumper to get the flash codes but the result I'm getting I am having a hard time figuring out.
I get 3 short flashes, a pause then 5 long flashes. From what I have read that tells me a code of 35, or a code 53, I'm not clear on that. There is no listing for either of these cades in anything I have seen.
Now if it is a code 3 and a code 5 both pointing to the MAP sensor, I have already changed that and I still have the problem.
Any insight? Thanks.
Old Feb 17, 2010 | 09:19 AM
4bangersurprize's Avatar
did you reset the computer after installing the new map sensor . If you go to Autozone they will pull the codes for ya. no charge.
Old Feb 17, 2010 | 09:31 AM
AutoZone does not pull OBDI codes. You need to do it yourself with a jumper wire.
Sounds like MAP sensor codes 3 and 5. Post a video of the blinking CEL codes if you want them verified.
Old Feb 17, 2010 | 09:48 AM
ok so what did they hookup to my car then, To come up with P0401 and P1491 emissions.
Am i missing something.
Old Feb 17, 2010 | 09:54 AM
Your car has an OBDII ECU whereas the OP has an OBDI ECU.
Old Feb 17, 2010 | 01:36 PM
ok cool now I know
Old Feb 17, 2010 | 01:37 PM
I like your avi
Old Feb 18, 2010 | 04:07 AM
Dipsetcivic117's Avatar
Wouldn't his code be 3 and 50 since he said 3 shorts and 5 longs?
Old Feb 18, 2010 | 04:39 AM
There is no code 50.
Old Feb 18, 2010 | 08:29 AM
Thank,RonJ,
So when you use the jumper wire, what flashes the engine light it self?
