Idle Air Control Valve
Hello everyone,
This is my first post and also my first import. I normally have pre 70's American vehicles so am new to this import thing. I have a 1995 Honda Civic DX with a D15B7 engine and i am getting a Code 1 (Oxygen Sensor) and Code 14 (IAC Valve) I'm not to worried about the Code 1 cause i will change the sensor but I tested the IAC and the resistance in within tolerance but the voltage being supplied to the valve is only 5 VDC, the manual says it should be battery voltage. Any suggestions on why only 5VDC are going to the IAC. Thanks in advance to any help |
RE: Idle Air Control Valve
Just so i'm reading the code right, after jumpering the plug I turn the ignition to ON and the CEL has 1 long blink then a long pause and then 1 long blink and 4 short one. That is a Code 1 and a Code 14 right?
Actually the first long blink is to let you know that there is a stored code. If it hadboth it would repeat the sequence of one long blink, then another long blink and four short ones. IACV's are a squirrely thing. Clean it out and see if that helps, otherwise you may need to replace it.
But what about the 5 VDC is that normal or should there be 12 VDC. Haynes manual just said battery voltage which to me is 12 VDC butI could be wrong
OK I rechecked the CEL again and this is what I get: 1 long blink a pause then 1 long blink and 4 short blinks then a pause and the sequence repeats itself.
Now according to the Helms Manual codes 1-9 are shown by just short blinks and 10-??? are long blink 1st digit and short blinks 2nd digit. The Haynes Manual says the first digit is a long blink and the second is a short blink So if you go by the Helms Manual all I have is a Code 14 if you go by the Haynes Manual I have a Code 14 and a Code 1 Now I'm Fracking confused. |
If you had both, it would bethree long blinks first then 4 short, and then repeat two long, 4 short. The first long blink is to let you know that there is a code. If you want to simplify it, AutoZone will read it for free.
Where are you from that your name is Cajun? |
I am from Carencro Louisiana
No kidding. I'm in Baton Rouge.
Cool maybe you can swing by and fix the car
lol |
Any ideas why only 5 VDC are going to th IACV
