Idle Air Control Valve
Old Feb 18, 2007 | 11:20 AM
cajunfive's Avatar
Default Idle Air Control Valve
Hello everyone,
This is my first post and also my first import. I normally have pre 70's American vehicles so am new to this import thing.
I have a 1995 Honda Civic DX with a D15B7 engine and i am getting a Code 1 (Oxygen Sensor) and Code 14 (IAC Valve)
I'm not to worried about the Code 1 cause i will change the sensor but I tested the IAC and the resistance in within tolerance but the voltage being supplied to the valve is only 5 VDC, the manual says it should be battery voltage. Any suggestions on why only 5VDC are going to the IAC.
Thanks in advance to any help
Old Feb 18, 2007 | 12:33 PM
cajunfive's Avatar
Default RE: Idle Air Control Valve
Just so i'm reading the code right, after jumpering the plug I turn the ignition to ON and the CEL has 1 long blink then a long pause and then 1 long blink and 4 short one. That is a Code 1 and a Code 14 right?
Old Feb 18, 2007 | 02:10 PM
Street Sniper's Avatar
Actually the first long blink is to let you know that there is a stored code. If it hadboth it would repeat the sequence of one long blink, then another long blink and four short ones. IACV's are a squirrely thing. Clean it out and see if that helps, otherwise you may need to replace it.
Old Feb 18, 2007 | 02:42 PM
cajunfive's Avatar
But what about the 5 VDC is that normal or should there be 12 VDC. Haynes manual just said battery voltage which to me is 12 VDC butI could be wrong
Old Feb 18, 2007 | 03:00 PM
cajunfive's Avatar
OK I rechecked the CEL again and this is what I get: 1 long blink a pause then 1 long blink and 4 short blinks then a pause and the sequence repeats itself.
Now according to the Helms Manual codes 1-9 are shown by just short blinks and 10-??? are long blink 1st digit and short blinks 2nd digit. The Haynes Manual says the first digit is a long blink and the second is a short blink
So if you go by the Helms Manual all I have is a Code 14 if you go by the Haynes Manual I have a Code 14 and a Code 1
Now I'm Fracking confused.
Old Feb 18, 2007 | 03:28 PM
If you had both, it would bethree long blinks first then 4 short, and then repeat two long, 4 short. The first long blink is to let you know that there is a code. If you want to simplify it, AutoZone will read it for free.
Where are you from that your name is Cajun?
Old Feb 18, 2007 | 03:47 PM
cajunfive's Avatar
I am from Carencro Louisiana
Old Feb 18, 2007 | 04:17 PM
No kidding. I'm in Baton Rouge.
Old Feb 18, 2007 | 04:40 PM
cajunfive's Avatar
Cool maybe you can swing by and fix the car
lol
Old Feb 18, 2007 | 04:43 PM
cajunfive's Avatar
Any ideas why only 5 VDC are going to th IACV
KILLER
Jun 11, 2006 09:56 PM
jim9418
Apr 25, 2006 11:22 AM
jim9418
Apr 21, 2006 06:01 PM
Hawk284
Sep 8, 2005 12:20 PM
jlh911
Jun 30, 2005 09:52 PM
