just put a turbo in my EG
Old Jul 30, 2007 | 03:33 AM
93sir's Avatar
Default just put a turbo in my EG
I just got done with my turbo kit...This is the first time that i am boosting my car. My question is what do i need to do when it comes to ECU, also ifi put in a missing link do I take it off once I put the ECU in...What is the best to do when it comes to my ECU. Im trying to run about 9psi...My ECU is a P72..Please let me know what i need to do when it comes to tuning im new to this and im stuck...
Old Jul 30, 2007 | 03:35 AM
93sir's Avatar
Default RE: just put a turbo in my EG
I have a b16a2 motor with t3/t4 setup.
Old Jul 30, 2007 | 07:44 AM
hondacivic97's Avatar
Old Jul 30, 2007 | 09:37 AM
Skrapdoggydog's Avatar
first off check out the stickies in the turbo section, they have tons of info for you.
if you don't have these parts already your gonna need:
1) bigger injectors (depending on your power goals)
2) high flow fuel pump
as far as your ecu goes you can have this company chip your ecu www.phearable.netafteryou get it chipped,drive your car to reputable tuner and have them tune your car with whatever software they use (crome/neptune etc)
alsoDO NOT add the bigger injectors until after your ecu is chipped. good luck and post some pics.
Old Jul 30, 2007 | 05:58 PM
93sir's Avatar
Can i drive with a missing link until i get the ECU chipped. I have a walbro 255lb pump in fuel injectors i dont have yet...im going with DSM450.
Old Jul 30, 2007 | 07:43 PM
FMU's are junk. if you drive around with it you could really harm your engine. just wait until the ecu is chipped and the injectors are in before driving the car. even after the ecu is chipped you have to take it easy until you get tuned.
be patient man, when going turbo you have to do it right. trust me it will be well worth the wait!!
Old Jul 31, 2007 | 03:13 AM
93sir's Avatar
I have a b16a2 motor will a p28 ecu fit my engine..Can i go with p28 and hondata s200 w/boost..Right now i have a p72ECU
Old Aug 1, 2007 | 03:21 AM
93sir's Avatar
Again. I was wondering if i can drive my vehicle with just missing link...What else do i need with this setup. I have a walbro pump. Do i need injectors?
Old Aug 1, 2007 | 05:50 AM
ScoobyAddict14's Avatar
formerly aryiman98civic
yes you need injectors, a chipped p28 and an obd2 to obd1 conversion harness. forget the missing link its gonna be junk anyway. you will blow up your engine soon if you do not get these because your car is running like **** im guessing. anyway after you get all those you need to contact someone who tunes for your car. crome is usually the program to go if you dont have hondata.
Old Aug 1, 2007 | 08:30 AM
93sir's Avatar
Why cant i just chip my p72. And isnt p72 already an OBD1.
