knock sensor interchangeability
Old Dec 23, 2010 | 11:23 AM
MaximusFunk's Avatar
Default knock sensor interchangeability
anyone know if the knock sensor from an integra will work ok with a d16y8? I have heard conflicting statements.
Old Dec 23, 2010 | 11:56 AM
Have you checked the parts numbers out? Maybe obd2a and 2b are different? Otherwise, a knock sensor is pretty simple with only one wire coming out the back. It grounds through the motor. The only other difference between the two I could imagine is the thread pitch, however, Honda usually does not make things that complicated.
EDIT -
Knock sensor part number from a 99 Civic EX = 30530-P2M-A01
Knock sensor part number from a 99 Integra = 90059-PR3-000
I would assume that they are in fact different by looking at the part numbers.
Old Dec 23, 2010 | 01:07 PM
ok, cool thanks. civic knock sensors are 30 on ebay and I found an integra one for 5. oh well.
Old Jan 19, 2014 | 04:35 PM
pps01ex's Avatar
wheir is the knock sensor located on my 7th gen its throwing a knock sensor malfunction code right now and tryin to fix it thanks
1998civicexauto
Jul 12, 2022 06:05 AM
trustdestruction
Oct 12, 2008 10:41 PM
jray0305usa
Sep 14, 2008 06:59 AM
drbyers
Oct 25, 2006 10:23 AM
drbyers
Apr 25, 2006 03:58 PM
