LC-1 use?
Old Jun 28, 2007 | 07:23 AM
cpl rampage's Avatar
Default LC-1 use?
Well, right now, i have a narrow band a/f gauge in my gauge pod. i was thinking about getting an innovate LC-1 without a gauge, i would then take the narrowband output from the LC-1 and send it to the ecu, and the gauge i have right now. i assume that would work correctly, and since it had the dataloging port, i can get the true wideband using the laptop, i also assume this would be easyer then installing their own wideband for whoever is tuning my car?
Old Jun 28, 2007 | 08:44 AM
SovXietday's Avatar
Default RE: LC-1 use?
Unless you're the one tuning the car, the only way that the wideband is really going to be benefitial to you is if you have a realtime gauge. That way you're getting instant feedback and you don't need to carry a laptop etc.
All of the wiring to the ECU etc only allows you to collect wideband readings for your datalogging.
Old Jun 28, 2007 | 08:57 AM
So it is pretty much pointless unless i am gonna have the laptop with me all the time right? so i should just add a second o2 bung to my dp when i make it? and then have the tuner use their own wideband?
Illholddamoney
May 3, 2005 12:32 AM
corye03
Mar 19, 2005 07:48 AM
Kappa22
Mar 15, 2005 11:46 PM
imadj
Mar 5, 2005 08:10 PM
green98lxsedan
May 15, 2004 03:35 PM
