Mini me ecu
Old Oct 7, 2004 | 01:55 PM
dmsteele92831's Avatar
Default Mini me ecu
What ecu should I use for a mini me swap of a ex d16y8, should I go with the stock ex p2p ecu or convert to OBD1 then get a different ecu? Keep in mind I am going to mill the head, port and polish it and eventually end up putting in a S/C.
Old Oct 7, 2004 | 06:13 PM
Importman04's Avatar
Default RE: Mini me ecu
What kind of S/C are you going with?
Old Oct 7, 2004 | 07:07 PM
Jackson S/C
Old Oct 7, 2004 | 07:56 PM
sacicons's Avatar
dont mill the head if you are planning to go FI. it will raise compression and you will have detonation issues with the SC. and personally, id go obd1. its a lot easier to tune.
Old Oct 7, 2004 | 09:50 PM
What is an OBD1?
Old Oct 8, 2004 | 10:45 AM
OBD1 is the electronic name for 92-95 civics (someone correct if I'm wrong) 96-00 civics are OBD2. You can buy a harness off Ebay from $50.00 to $150.00 that will convert your OBD2 civic (96-00) to OBD1. The reason it is preferable to do this is because you can run a P28 ECU (or any other that you want) and they are easier to tune and chip than the OBD2 ECU. I'm going to convert to OBD1 and get the p28 ecu and have it chipped. By chipped they raise the fuel/air curve, adjust the vtec (sometimes) and it supposedly adds 10-20 Hp depending on what you have done ie. headers, intake, exhaust, cam etc. One guy off ebay will even ask you all the mods you have then chip your ecu accordingly
civic96lx
17
Sep 20, 2010 09:37 AM
museboy07
Apr 28, 2008 02:42 AM
FlipHKD720
Oct 13, 2006 09:43 PM
khanselman
Aug 25, 2006 12:40 PM
GSXF
Feb 23, 2005 09:45 PM
