misfire?help
hey guys, my tuner ditched out on me a week ago to tune my car and since he jsut messed with it, its running like crap. i have the greddy kit for a 98 civic with emanage blue. before i added the aem fuel rail and walbro pump and 750cc the car ran fine. i took the 750's out and put the 310's in. the car runs fine till im just steady throttle it will go lean for a sec and bouce back to normal. any ideas aside from getting rid of the emanage right now. the fuel pump too much? or the fuel rail? that shouldnt matter right.very lost
Sorry to hear about your tuner. I bet he found out you were running an E-manage and backed out. LOL j/k
You say you are ditching the E-manage? What will you be replacing it with?
You should be fine with 750's, as long as it is tuned correctly. I believe the 310's run better because they are "closer" to the stock 240's, which is what your ecu is thinking should be there. Regarding the lean spot you see, you should be able to add fuel to that area of the map and see the AFRs come back.
ok some confusion. i had stock rail and pump with 310's car ran ok. i put 750's aem rail and walbro and car wouldnt start.put 310's back now while driving it goes lean and back to normal. thats y im thinking the pump. when i let off the gas an hit it . it studders
update
i put stock fuel rail in and stck pump, car still hesitates around 2500rpm goes from 14.a/f to 17(lean) for a sec then back to 14ish while normal driving. but fine under hard accel that i can tell. anyone?
i do have the stock injectors, maybe ill try em, i disconnected the emanage and ran right on my ecu and the trouble still occured. i disconnected my primary o2 and the car ran great alil rich but no hesitation. kinda leaning toward that now. i have no check engine light. this is annoying
