Non vtec throwing a v-tec error cel (22)
Flip, the basemap gets put onto a chip, which gets placed into the socketed ECU, they are two separate pieces. He got a new CHIP from Phearable, which has the basemap on it.
i know i understand that, he just said he "chipped" his ECU, and i didnt know that menat the same thing as socketing his ECU (prepared it for use with a new chip)
double check again to make sure that is the code you're getting... then email phearable and tell them what's up. I don't really have an explanation
they might say you messed up with the socketing... have you done it before? just wondering.
ORIGINAL: mxs
Did you socket it to P28 spec? If so, that would be your problem.
Either that, or VTEC is enabled in the basemap, that would probably cause the CEL to be thrown anyway. There's no way to just get rid of the highcam maps in Crome, but you can disable VTEC and therefore "hide" the highcam stuff.
http://www.phearable.net/images/ecusocketingins.gif
I drove it to the muffler shop todayto get the downpipe shortened, It drove perfect with 450's and the phearable map. @ 3k rpm and less. Still can't get app. at dyno till Mon. or tues.
