OBD 2 check engine light question
Old Dec 9, 2005 | 11:06 AM
Talon585's Avatar
Default OBD 2 check engine light question
I called the dealership today to have them check what code im throwing. The service manager says to go outside and click my gas cap three times tighter and see if the code turns off in three days. Mainly because when the light turned on nothing noticable happened and still hasnt happened. Has anybody experienced this before? Wish i could check that code myself.
Old Dec 9, 2005 | 01:06 PM
Marty's Avatar
Default RE: OBD 2 check engine light question
Sounds like vapor lock, it is when the gas fumes create a pocket of suction so to speak and it kinda keeps your fuel pump from pulling enough fuel. Kinda like if you had a 2 liter mt. dew bottle and you were trying to drink out of it with a straw but it has a hole in the bottom of it hooked up to a shopvac. The dealer did not tell you what code it was throwing? Go to advanced auto or autozone and they will pull the code for free and tell you what it is/how to fix it.
Old Dec 9, 2005 | 01:29 PM
Talon585's Avatar
Well he wanted me to check his method before i bring the car in to get the code pulled.
Old Dec 9, 2005 | 02:06 PM
Marty's Avatar
I have never seen vapor lock throw a code on a ecu on any car let alone a civic. you can try it though
Old Dec 11, 2005 | 10:55 PM
AgentofDarkness's Avatar
Isn't vapor lock when the fuel system doesn't hold residual fuel pressure? If so i think the FPR needs to be changed.
Old Dec 11, 2005 | 11:26 PM
sacicons's Avatar
vapor lock is almost nonexistent on modern cars, but the loose cap throwing a code is pretty common. kinda stupid, but im sure it has some kind of reason for triggering one. but that sounds like the mech is grasping at straws. go to autozone and see if you can get the guys there to use a diagnostic tool and pull the codes. but hey, try the gas cap thing, if it works, then cool, it was a free fix.
Old Dec 12, 2005 | 10:58 PM
Actually the loose gas cap throwing a code isn't stupid at all. The whole point of OBDII is to reduce emissions. A check engine light will come on when there is a problem with emissions. When the gas cap is loose, fuel vapors are released into the atmosphere. This is bad for the enviroment and hence the code.
Old Dec 12, 2005 | 11:30 PM
97CivicEX's Avatar
I would recommend you to take it to an autozone. they will read the code for you FOR FREE! Don't waste your time with the dealership. after you get the code read, come back here and post the number(s). make sure you have something to write it down with.
Old Dec 13, 2005 | 06:02 AM
Talon585's Avatar
Well the CEL came back on again this morning. Even though i hate to do it, im going to take it to autozone. Makes me fell bad when i go there to get the code read and i dont buy anything from them but whatever.
Old Dec 13, 2005 | 08:52 AM
Chimera02EX's Avatar
$10 says its a O2 code.
