obd1 ECU obd2 engine...
Old Sep 18, 2006 | 12:20 PM
Zer0Ale's Avatar
Default obd1 ECU obd2 engine...
i swapped the engine on my 94 civic LX to a 96 d16y7...i wantd to know if i needed a harness to get rid of the CEL n would one b needed for my future mods (I/H/E/turbo/hondata). if so which harness do i need, thanx in advance
Old Sep 18, 2006 | 12:31 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: obd1 ECU obd2 engine...
what's the code you're throwing?
Old Sep 18, 2006 | 12:38 PM
Zer0Ale's Avatar
the code is 14 idle air control
Old Sep 18, 2006 | 12:39 PM
Cat Fuсker
here's the thing, the IACV that you have is a three wire piece. The one on OBD1 are 2 wire ones.
Old Sep 18, 2006 | 12:47 PM
Zer0Ale's Avatar
does that mean ima b stuck with the CEL or can something b done
Old Sep 18, 2006 | 12:49 PM
Cat Fuсker
I really can't help you with the answer, but this is the issue that you're having. try searching from there. it's also possible that you bought an engine with a bad IACV, can you try to use your old one?
Old Sep 18, 2006 | 01:00 PM
Zer0Ale's Avatar
no the old engine is gone but ill try to do more searchin to solve my problem
Old Sep 18, 2006 | 01:19 PM
Cat Fuсker
POSSIBLY a two wire IACV from an older civic will work. Can't tell for sure though.
Old Sep 18, 2006 | 01:37 PM
Zer0Ale's Avatar
ima try to find one the IACV aside...do u know if hondata or chippin the ecu works on an automatic/ non-v-tec
Old Sep 18, 2006 | 05:12 PM
Cat Fuсker
OBD1? Sure. P06 ECU? Chipping works perfecto...
