starting to go nuts
Old Feb 24, 2006 | 10:21 AM
top99sir's Avatar
Default starting to go nuts
Ok I am being told that I need to convert to a OBD1 from a OBD2 ECM if I want to run uberdata or hondadata softwhere. Personally I don't give a sh** what softwhere I have to use what I want to Know first is, can a OBD2b ECM be modified and re-programed. can someone please give me a COMPLET list of parts, hardwhere and whatever els I will need to set my car up to be programed??
Old Feb 24, 2006 | 10:34 AM
usmc2b2004's Avatar
Default RE: starting to go nuts
Are you going with a Piggy-back or are you having your ECU reprogrammed?
Old Feb 24, 2006 | 12:06 PM
ef4life's Avatar
to convert the car to obd1 just get a conversion harness from www.jkobd.com or www.boomslang.us
Old Feb 24, 2006 | 12:37 PM
Marty's Avatar
You also need a obd1 ecu(P28)
Old Feb 24, 2006 | 02:34 PM
jwsimons's Avatar
the answer i beleive, is, no. you cannot do what you want with obd2, all the programs are written for obd1
Old Feb 24, 2006 | 06:18 PM
Street Sniper's Avatar
You will need OBD-1 to tune. Get a conversion harness (Rywire.com is the bomb), a p28 and get it socketed. Then download Uber or chrome or go buy Hondata s300 from Speed6motorsports.com. You will also need a wideband oxygen sensor. Start doing a lot of reading and get to it. PGMFI.org
Old Feb 24, 2006 | 06:27 PM
top99sir's Avatar
ok so I have no choice but to go to OBD1. I have been told that I need the obivious, OBD1 ECU and conversion harnes, but I was also told I need a OBD1 distributer and 4 wire o2 sencor. is this right
Old Feb 26, 2006 | 11:31 PM
jwsimons's Avatar
honestly, i dont know, im unfamiliar with the difference in dizzy's. i would start at hondata's website, they have an aplication wizard that will tell you exactly.
Old Jul 10, 2006 | 11:07 AM
hazo vti's Avatar
I AM HAVING THE SAME PROB!!!!!!!! OBD2B IS S**T WOTS THE POINT OF IT!!!!!!!!!!!!
Old Jul 14, 2006 | 06:39 PM
pregohatch's Avatar
you can still use ur stock distributor just get any obd1 ecu except for a vx and get it cheaped and tunned and you be fine the computer does not have to be vtec the tuner can change that if he use chrome program chrome is ****
Prego
totenkopf
May 31, 2007 03:36 PM
toomyboy
Oct 14, 2006 01:32 PM
Mossy
Sep 22, 2005 10:50 AM
kdillard12
Aug 18, 2005 11:10 AM
steven87ukuk
Jan 4, 2005 02:27 PM
