what ecu for my set up
i have a b16a head with a b18c block whats a better ecu a p72 a p28 or a p30 or should i get skunk2 ecu and what kind of camshaft i should get wanna run a t3-t4 hybrid turbo i dontno if i should go skunk2 stage 1,2or stage,3 camshaft and what kind of pistons and rods this is only a summer car so if somebody can help me out on bulding my motor thanx
you can get away with a p28 if you have engine management such as hondata. as far as cams go you can get away witha turbo spec cam from any name brand company.
but if you are jus building a summer car, then you can get away with stock cams and stock internals as long as you haev a set of 450cc injectors with a resistor box and a Vafc2 hack set up will suit you jus fine. jus make sure to keep the boost below 12psi and you will be happy and fine,
also look into a stage 2 exedy clutch, their rated for 400 hp. and they'll hold up to anything yo ucan throw at it
but you honastly dont need to build a motor for boost on a b16/b18 setup.
one more question...
Is it an LSvtec setup?
if it is then i would recomend only reving out to about 7500 rpm or less
driverosp0
Nov 12, 2009 05:41 PM
TurboToyzz
Feb 16, 2007 12:46 AM
