why do i have 2 switch my ecu?
Old Mar 7, 2007 | 11:21 PM
ic892003's Avatar
Default why do i have 2 switch my ecu?
when doing a mini-me swap of a z6 head on a d15 block y do i have to change my ecu to a p28??, i noe the air/fuel rations change, i noe u have 2 use the ecu that goes for ur head, but wouldnt it effect the pistons in anyway?
Old Mar 8, 2007 | 08:17 AM
Default RE: why do i have 2 switch my ecu?
what? How would it affect the pistons?
You need a VTEC ecu if you're going to put a VTEC head on your motor.
Old Mar 8, 2007 | 09:30 AM
FlipHKD720's Avatar
yes, you will ahve all the VTEC parts, but with your stock non-VTEC ecu your car doesnt even know what VTEC is. You need the new ECU to tell your car you have VTEC and when to kick it in. Its the brains behind the whole thing.
But i dont think swapping heads affects the pistons at all.
Old Mar 8, 2007 | 12:56 PM
ic892003's Avatar
yea i understand that, i jus wanted to know , since its gunna give out a 11:1 comression ratio, wouldnt that be high for the pistons
Old Mar 8, 2007 | 01:31 PM
FlipHKD720's Avatar
couldnt tell ya, but it seems like alot of people have swapped a z6 head onto your d15 block before and i havent really heard of anyone else having compression problems
Old Mar 8, 2007 | 06:09 PM
Kedawei's Avatar
Just run 91/93 octane on the P28 ECU and retard your ignition timing manually a bit.
danomatic93
Routine Maintenance DIYs
Jan 15, 2012 07:16 AM
AuroraEP3
Apr 10, 2009 09:48 PM
dblclutchin
Nov 14, 2006 01:40 AM
dblclutchin
Jul 4, 2006 03:46 PM
