HondaCivicForum.com
-   ECU Tuning & Fuel Management (https://www.hondacivicforum.com/forum/ecu-tuning-fuel-management-33/)
-   -   Wideband o2 Questions (https://www.hondacivicforum.com/forum/ecu-tuning-fuel-management-33/wideband-o2-questions-43479/)
FlipHKD720 05-02-2007 09:26 AM
I've researched quite a bit, but havre some questions about wideband o2 meters. I know they plug into the original o2 sensor bung and give you an accurate reading, but does it plug into the laptop you are tuning with, or is it just a gauge that you read before and after you make tuning adjustments? I was looking at this: http://www.innovatemotorsports.com/products/lm1.phpand noticed it included various cords. Can anyone give me in pretty simple terms how it works?
EDIT: and also on this site: http://www.forparts.com/BoswidebandO2diag.htmit talks about "new contorl strategies made possibnle by the wideband o2 sensor". So does the wideband actaully make adjustments to the A/F ratio, or does it just monitor it?
ScoobyAddict14 05-02-2007 09:39 AM
RE: Wideband o2 Questions
the wideband hooks up to your ecu and then you have a cord that comes off the ecu which plugs into your laptop.
FlipHKD720 05-02-2007 09:45 AM
does the wideband itslef make adjustments or just monitor it? I always thought the the tuner program makes adjustments thoughright?
riceburner700 05-02-2007 10:21 AM
the tuner just looks at the wideband as to see whats going on because its more accurate than a narrowband
FlipHKD720 05-02-2007 11:15 AM
k thanks you guys
