Wideband o2 Questions
Old May 2, 2007 | 09:26 AM
FlipHKD720's Avatar
Default Wideband o2 Questions
I've researched quite a bit, but havre some questions about wideband o2 meters. I know they plug into the original o2 sensor bung and give you an accurate reading, but does it plug into the laptop you are tuning with, or is it just a gauge that you read before and after you make tuning adjustments? I was looking at this: http://www.innovatemotorsports.com/products/lm1.phpand noticed it included various cords. Can anyone give me in pretty simple terms how it works?
EDIT: and also on this site: http://www.forparts.com/BoswidebandO2diag.htmit talks about "new contorl strategies made possibnle by the wideband o2 sensor". So does the wideband actaully make adjustments to the A/F ratio, or does it just monitor it?
Old May 2, 2007 | 09:39 AM
ScoobyAddict14's Avatar
formerly aryiman98civic
Default RE: Wideband o2 Questions
the wideband hooks up to your ecu and then you have a cord that comes off the ecu which plugs into your laptop.
Old May 2, 2007 | 09:45 AM
FlipHKD720's Avatar
does the wideband itslef make adjustments or just monitor it? I always thought the the tuner program makes adjustments thoughright?
Old May 2, 2007 | 10:21 AM
riceburner700's Avatar
the tuner just looks at the wideband as to see whats going on because its more accurate than a narrowband
Old May 2, 2007 | 11:15 AM
FlipHKD720's Avatar
k thanks you guys
FlipHKD720
Mar 13, 2008 04:47 PM
asdfbrendan
Oct 25, 2007 08:35 AM
b8teen
May 2, 2007 12:29 PM
JDM_HONDA_LOVE
Aug 15, 2006 09:24 AM
riceburner700
Mar 23, 2006 05:36 PM
