wont start
so i have a 90 civic hb.drove fine everyday,i had to get surgery on my sholder so i couldn't dive if for about a month.so finally im able to use my arm and wanting to drive my car.try to start it and nothing k so it's the battery right.i got another battery and my car then want's to start but doesn't and all my lights,brake lights,dome light dont turn on the only thing that does work r my hazards.please help i checked all the wires that hook up to the battery and there all connected
-Check for blown fuses under the dash and hood.
-Check for spark at the plugs and listen for priming of the fuel pump. -Pull the carpet back from the ECU under the front passenger dash and check for trouble codes blinking from the LED. |
check your ground wire... double check the battery wires and make sure everything is tight
make sure battery is charged.. |
Originally Posted by RonJ
(Post 663370)
Oh, you have an OBDI P30 ECU. Then jump the service connector and watch the blinking code(s) from the CEL.
Click Spark link in my signature. This tells you how to check for spark at the plugs. Turn the key to ON(II). Do you hear the low humming sound of the fuel pump priming for 2 seconds? |
did you check the main fuse box under hood there is little square red and yellow boxes make sure they aint blown and aslo they have screws on each side of them.
(Post 663468)
(Post 663433)
I really appreciate your guy's help,im almost there
you are still lacking power9(+-12v) from somewhere.
recheck all your fuses under hood and dash.. have you tried to jump the starter... put car in nuetral first then turn key to the on position and on the starter there is 2 wires going to it...take a good piece of wire and touch both pieces on the starter together to start engine.. |
