ED-EF Swaps 1991 and older Civics, CRXs
...DPFI to MPFI...
Old Mar 21, 2007 | 11:43 AM
89_slammed's Avatar
Default ...DPFI to MPFI...
ok. Im about to do the fuel injection swap on my d15b. I already have the resistor box from an accord. The question is since the stock pm5 only has 2 injectors am i going to need to get another ecu to run the additional wires for the injectors... it only makes sense. But i wanna make sure so this bitch will run.
Any help is thankful. thanks guys.
Old Mar 21, 2007 | 12:41 PM
bakertime's Avatar
Default RE: ...DPFI to MPFI...
Whoa dude, triple post?
Old Mar 21, 2007 | 02:33 PM
Street Sniper's Avatar
I didn't see the others, but yes, you needthe Si ecu. p06 I believe.
Old Mar 22, 2007 | 01:17 AM
finalimpact's Avatar
si/ex ecu= pm6.......you can also use the 88-89 teggie pg7 ecu and the 90-91 teggie pr4. you will also need a 88-91 crx/civic si,hf,ex distributor, 4 88-91 civic/crx, ex, si injectors, 88-91 crx/civic si,ex intake manifold. since you have the resistor box the rest is labor in wiring.
Old Apr 12, 2007 | 11:49 AM
markwilson's Avatar
Ya you need an ECU. I just did the change and noone told me my DX ECU wouldnt work. 88-91 CRX or SI also I think an 88-89 Acura Integra will work.
Old Apr 12, 2007 | 04:06 PM
skateman190's Avatar
so on my dpfi to mpfi with my b16 i can use my b16 ecu right? or do i need another one too? sorry to thread jack btw just have a similar question
Old Apr 22, 2007 | 02:53 PM
correct assuming your b16 and ecu are obd0. unless youve done an obd1 conversion. obd0b16 ecu's= pr3/pw0
civicraider
Sep 18, 2006 12:52 AM
speedstream
ED-EF Swaps
Sep 9, 2006 08:00 PM
Patrick
Drivetrain DIYs
Jan 4, 2006 11:05 AM
barryscivic
ED-EF Swaps
Aug 25, 2005 10:36 PM
ohbiskits
Jun 22, 2004 02:41 AM
