ED-EF Swaps 1991 and older Civics, CRXs
zc
Old Apr 7, 2005 | 09:53 AM
hondabboy's Avatar
Default zc
hey i just got a real good deal on a zc motor for 150. it includes the motor (of course),distrub,alt,starter,intake mani,exhaust mani,hearders,ecu,axles,tranny.
i dont know about the wire harness tho i didnt ask him about that but i wanted to know what else do i need for the swap in my civic. i know its a kinda like a direct bolt on (w.o after market motor mounts). and i can use my si tranny on it anyways gimme some info about this swap cause im kinda getting the motor by the end of this week. thanks alot.
Old Dec 12, 2005 | 06:40 PM
ef4life's Avatar
Default RE: zc
the wiring harness should not need any modification you should just be able to plug it in if you already have multi point fuel injection. i never helped swap a zc so check around with other forums until you are sure. the engine should just bolt in because it is related to the d series, so headers will work. an intake might not because of the dual cams if a intake for a d series ef won't work a b series might i don't know. make sure you have the proper ecu also.
Old Dec 12, 2005 | 09:07 PM
Kappa22's Avatar
Default RE: zc
Thread from the dead. I believe he has a different car and an LS swap now, but I'm not sure.
