Another B20 Question
Thanks for the input in the last post. But if decide to go with a 92'-95' Civic coupe will i need to splice the harness because that is something i dont want to do, and if i go with either an EK Hatch or a 96' to 99' Civic Sedan (I want something a little different) will the harness that comes with the B20Z/B plug right into the Civic's harness and will the LS ECU plug into the Civics connectors. Thanks for the help
RE: Another B20 Question
You wont need to splice anything. If you use the 92-95 civic u would use the OBD1 LS ECU, If u use 96-00 civic you would use OBD2 ECU. I agree with sacicons. My LS is turbo'd and has been runnin strong for over a year now runnin 10-15 PSI.
you could always go dfifferent with an old school 88-91 civic wagon, and get a www.rywire.com harness built so you just put it in, plug it in, and drive away.
