EG Swaps 1992-1995 Civics
D15B questions.
Old Aug 22, 2005 | 05:23 PM
vestalzr2's Avatar
Default D15B questions.
I just got a 93 LX with the D15B7 16V 102Hp etc... It needs an engine the last owner ran it with out oil and it broke the cam So I want to do an engine swap. Nw here is my question(and yes I have searched please dont kill me :P) on a 16V d15B engine as long as it is a 16 V version(unlike the the D15B8, and D15B1 which are 8V) will it be a "plug and play" operation. I'm not looking for Hp here just MPG. All help will be appreciated...sorry for being NOOB[]
Old Aug 22, 2005 | 07:30 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: D15B questions.
I think the JDM D15B has two VTEC solenoids...don't know how that works.
Old Aug 22, 2005 | 08:05 PM
vestalzr2's Avatar
yeah I dont want a Vteah engine. I dont want to deal with the hassle of that big of a swap.
Old Aug 22, 2005 | 10:59 PM
Mad7s's Avatar
The level of intelligence, no, common sense some people have regarding cars kills me. You shouldn't own a vehicle if you don't understand the simplest of its operating necessities.
Old Aug 23, 2005 | 07:27 AM
Cat Fuсker
running two more wires is well worth it to swap a VTEC engine in...I just don't know about the JDM D15B
Old Aug 23, 2005 | 08:59 AM
vestalzr2's Avatar
I relize that the Vtec enigine is a awesome enigine. but I'm building this car for MPG not HP. This car will be my DD.
Old Aug 23, 2005 | 08:30 PM
Cat Fuсker
There is VTEC-E ... the economy version of it...or the D15B with the three stage VTEC which is also economy oriented on the low end...VTEC-E will be your best bet though...
Old Aug 25, 2005 | 09:36 AM
vestalzr2's Avatar
ORIGINAL: Kolhoznik
Ok I've been doing some searching around/. I knew they made the D15Z1 engine. From what I have found you do this swap I will need the engine, ECU. I will also need to wire in the V tech solenoid, and the 5 wire O2 sensor. is that right? what about the tranny? will i be able to use the same one thats in there now? Yet again sorry for being a noob. but atleaset I'm some what educating :P
Old Aug 25, 2005 | 10:31 AM
Cat Fuсker
You will need to do the wiring(Haynes manual has the diagrams) and you can keep you existing tranny. Engine and ECU are all you're gonna need...it's a good idea to change everything that is sometimes referred to as 60K maintainance... i.e. timing belt and water pump...
Old Aug 25, 2005 | 10:49 AM
vestalzr2's Avatar
Thats the heat. as far as the swap goes will i need to get a COMPLETE engine ie exhaust manifold, intake fuel injectors etc... I've got the haynes manual I didn't see the wiring differences. but I ordered a factory repair manuals on CD so maybe that will have it too. \
Thanks for all the help
