EG Swaps 1992-1995 Civics
d16z6 into 1992-1995 CX
Old Dec 4, 2005 | 03:26 PM
theharlequin's Avatar
Default d16z6 into 1992-1995 CX
What do I need to do a full z6 swap into a cx? i will use the p28 ecu since both cx and the ecu are odb1, so do i have to do any special wiring or use a different engine harness?
Old Dec 24, 2005 | 09:13 PM
95z6hatch's Avatar
Default RE: d16z6 into 1992-1995 CX
the only thing you should need are the v-tec wires( i just ran regular 16 gauge wire from the ECU pins that it needed through the fire wall to the soloniod. and i forget if you need 4 wires for the O2 sensor, ive seen stock cx's with and without 4 wire for some reason. also have to run all the other oil pressure v-tec wiring stuff
Mitch
thakid
Sep 13, 2006 01:10 PM
thakid
Sep 3, 2006 11:47 AM
civictuner
Jul 5, 2006 09:24 AM
NYC Civic
Oct 23, 2005 04:34 AM
redlines4us
Apr 27, 2005 10:42 PM
