EG Swaps 1992-1995 Civics
engine swap rough idle
Old Nov 3, 2009 | 03:36 PM
dicke336's Avatar
Default engine swap rough idle
i have a 93 eg that i swapped a d16 into. it ran fine for about 6 months till it sat for 6 more months. now the engine fluctuates at idle. i checked for any vacuum leaks and i wasnt able to find any. please help. any ideas
Old Nov 3, 2009 | 04:01 PM
hamorhead's Avatar
clean out your iacv if it persists clean out your fitv
if you dont know how google is your friend to learn how to clean them
edit: also try running seafoam through it and check your timing
Old Nov 3, 2009 | 05:12 PM
plethoric33's Avatar
If it sat for a long time the gas might just be bad, try running it low and filling it up fresh. I dont think it would be your IACV or FITV since its been sitting, they wouldnt have had a chance to clog. Also try bleeding your coolant lines, air bubbles in the lines can cause an idle surge.
Newbie2000ex
Oct 23, 2011 05:06 PM
armando.408
May 22, 2011 12:40 PM
Stumasters
Jan 20, 2008 12:58 PM
drbyers
May 24, 2007 01:50 PM
kjreinha
Feb 4, 2005 01:58 PM
