ef rough idle put new used engine?/ help
Old May 22, 2011 | 12:40 PM
armando.408's Avatar
Question ef rough idle put new used engine?/ help
just bought a 90 civic ef hb someone put an si ecu wit a d15b2 it ran but shaky cause the upper tranny mount,the gauges were swapped no lights oon or anything i swapped out the engine for a newer used engine out a 94 civic that is clean d15b7 it runs but i have the same issue when i try an gas it it wont stay on it will sputter and go out?? i had to use the same throttle body out the old b2.. i thinkk it could be the injectors but im not to sure??maybe the fuel pump? thanks
dicke336
EG Swaps
Nov 3, 2009 05:12 PM
biocpu
Oct 6, 2008 12:16 PM
Stumasters
Jan 20, 2008 12:58 PM
drbyers
May 24, 2007 01:50 PM
slideman99
Aug 3, 2004 06:10 PM
