i cant redline 7200rpm on my civic.. i can only go to 6200
will i dont know if you anyone knows this but... i have a difficult problem with my honda civic coupe... ( d16z6 )... i had a p28 ecu and it dont let me redline at 7200rpm.... it only goes to 6100rpm.... and i'm getting burned...hahaha.. but if you know what to do in my situation... please help me.. i'm new at this thing so if you can that would be great ... oh yea.. and i had a friend that told me it might be my ecu so i put in his p28 and it still does the same thing.. i tried reseting my ecu and it still doesnt satisfy me.. so help me you racers...
_____________________________ |
RE: i cant redline 7200rpm on my civic.. i can only go to 6200
could be something simple like...maybe the tach is off 1000 rpms
i wish is was that simple... hahaa.. but no its not that.. do you think i need to re tune my ecu??? or just chip it
go to phearalbe.net and get you a good ecu you can tell them how you want !!!!
well with a known good ecu tried and still not working, chipping isn't gonna do **** fella. look to other things, any CELs, when is the last time the cap rotors and plug wires were changed? how are your stpark plugs?
contrary to belief on this board, redlining is BAD.
you dont make power to redline
my car did the exact same thing (d16z6) w/p28 ecu too..what i did was i changed the rotor,cap,spark plugs, FUEL FILTER do that b/c i changed everything and forgot to change that and when i did it stopped being gay, spark plug wires, and change your oil and it should do it...those are the things i did and its perfectly fine..all it needed was a little bit of a tune up
Hey there would be a DIY for fuel filter if Remmy would do his job. [sm=drlove.gif]Hearts[sm=drlove.gif] for Remmy!
redlining isn't really bad, overrevving is. the honda engineers made the decision that the 7200 rpm limit on the tach is AOK for relialbility, but max power is at 6800rpm, so there is no need to go that high.
now redlining in every gear everytime you get in the car is bad, we call that abuse, and it makesyourcar as reliableas an 86 ford escort with 130,000 miles on it. |
