mini me?
i just recently picked up a 93 civic 4 door. in the process i read the engine code it says d15b7. but noticed it was a vtec. after buying it i checked into it more and found out that its a d15 with a y8 head. from wat ive found this would be the mini me swap correct? now me issue is that it make alot of valve noise def. could use an adjustment but whoever did the install kept the stock ecu and the vtec is not even hooked up. whats the best way to hook up the vtec and wat will i need?
khanselman
Aug 25, 2006 12:40 PM
