EG Swaps 1992-1995 Civics
what would u do?
Old Feb 18, 2006 | 10:46 AM
95 Civic B16A's Avatar
Default what would u do?
i have a JDM B16A Swap in my 95 civic coupe and i was wondering if it would be a good idea to swap the B16A out with a B18C5? What would you do? Swap it out or leave it alone?
Old Feb 21, 2006 | 01:55 AM
C5SpoonEG's Avatar
Default RE: what would u do?
Id go JDM B18C [X(]
Old Feb 21, 2006 | 02:21 AM
Whitelightning93's Avatar
Unless your getting the B18 for free, why dont you just boost the B16 and monster the hell out of it. You can find a top of the line kit that runs on your stock internals. Both are about the same price.
Old Feb 21, 2006 | 02:50 AM
NTX's Avatar
NTX
ORIGINAL: 95 Civic B16A
is there a reason you would want to swap?
Old Feb 21, 2006 | 06:11 PM
C5SpoonEG's Avatar
honestly Id boost your b16 , sleeve it, tinker with the cams etc...
Old Feb 22, 2006 | 06:46 PM
FastFwd's Avatar
i've almost finished installing my turbo kit on my b16a2. search on ebay for a second hand greddy kit. there are always a few floating around. i would deffinatly turbo the b16 or if your looking to keep is NA, get some cams, valve spring kit, headers, vafc and a few other mods and that should give you a good increase in HP.
Old Feb 23, 2006 | 04:23 PM
AgentofDarkness's Avatar
I would build the B16. The only reason that i would swap in a B18 would be if i had a D series or a non-vtec. Save the 3k you would be spending in the swap and use it to build the lower end, sleeves, maybe a stroker kit, cams, valvetrain, etc. After you do the work, then you will prolly make more power than with the B18 alone, especially if your able to get a turbo as well.
ef4life
Jul 26, 2007 09:11 AM
mrcarbon
Apr 1, 2005 09:32 PM
White_Devil
Dec 5, 2004 03:04 PM
fast93civic
Nov 27, 2004 01:02 PM
duffycivic
Aug 6, 2004 10:55 AM
