EG Swaps 1992-1995 Civics
Whats differences between long block and regular?
Old Oct 25, 2006 | 01:18 PM
b16avtec's Avatar
Default Whats differences between long block and regular?
what are the differences between b16avtec Sir II long block and regular b16avtec?
would a long block engine fit into a EG hatchback?thanks
Old Oct 25, 2006 | 02:12 PM
Misha's Avatar
Default RE: Whats differences between long block and regular?
Long block (as opposed to short block) is just the name of specific set of engine spare parts. If I'm not mistaken, short block includes only block itself, when long block includes everything assembled except for head and external equipment.
Old Nov 1, 2006 | 09:30 AM
HARI.'s Avatar
longblock means everything w/ the motor except transmission.
a b16 long block will fit in your EG chassis, but you will need to get a b-series transmission, from a 94-01 integra. you're better off buying a complete swap
Old Nov 1, 2006 | 09:50 AM
Misha's Avatar
http://en.wikipedia.org/wiki/Long_block
Kid, please say when you have something to say, not when you have to say someting
Old Nov 1, 2006 | 12:27 PM
HARI.'s Avatar
ORIGINAL: Misha
who are you talking to?
Old Nov 1, 2006 | 12:54 PM
Misha's Avatar
Obviously to you, if you are replying
Old Nov 1, 2006 | 01:40 PM
sbowers's Avatar
well if you read the definition correctly yourself you would see that a long block includes the cylinder head
Old Nov 1, 2006 | 01:52 PM
Misha's Avatar
Absolutely. I did not remember this in full detail when replying, and did not find the link, so i put there "If I am not mistaken". Means: I'm not sure in the answer, this is the best I can try now. And I think, it was enough to answer the original question, if you read it. My answer states that regardless of being short or long block, this is absolutely the same b16avtec engine, just with more or less parts bolted to it
Old Jan 14, 2011 | 09:27 PM
tj1114's Avatar
Red face
Don't mean to thread hack and I may have missed this reading through but would a long block engine such as the F20B 97-98 fit into a1991 honda civic?
Old Jan 14, 2011 | 10:04 PM
MBrent's Avatar
July 2010 ROTM
check the thread date, and also, the term "longblock" has nothing to do with the length of the block. it merely means that it is a complete engine. a shortblock is the block and rotating assembly only. longblock includes the head. an f20b if im not mistaken(lol), is a destroked h22. you will need the proper mounts, axles, trans, and ecu/wiring, but it will fit into an ef. i assume you have stumbled across a bluetop somewhere?
