EK Swaps 1996-2000 Civics
1997 CX B18B swap problems
Old Mar 30, 2008 | 09:25 PM
Mr. Chainsaw's Avatar
Default 1997 CX B18B swap problems
alrighty, after about 3 days of pure hell, I completed my swap. the car is a '97 CX hatch, motor is a '00 LS. I used the cx wiring harness, and did the IAC trick at the ecu. i'm still running the ecu out of the d16. everything seems to work fine, the car pulls like a mother. problem is... speedo doesn't work, and, if i barely put my foot on the gas, it acts like i'm on a 2step. I can rev past that spot and everything is gravy. its just at low rpm's it bounces around, kind of annoying. would it be remidied by putting a ecu out of say, a 96-98 LS ecu? I dunno, i'm out of ideas.
Old Mar 30, 2008 | 09:29 PM
jpnolan's Avatar
Default RE: 1997 CX B18B swap problems
ya im pretty sure you need that ecu that should solve your problems
Old May 16, 2009 | 08:09 AM
murdayou's Avatar
wow why would you keep an ecu from a d series in your car no offense but its jus stupidity thats your problem
Old May 16, 2009 | 12:30 PM
plethoric33's Avatar
You def need the LS ecu.
Old May 16, 2009 | 09:17 PM
Umm, your current ECU is for a 1.5L SOHC 8-valve engine, and now you have a 1.8L DOHC 16-valve engine. It's just a tad bit obvious that it's the problem. Get the correct ECU.
Rsporty
EG Swaps
Feb 7, 2010 06:01 PM
jspec95
14
Jan 29, 2006 04:07 PM
jspec95
Jan 16, 2006 08:06 PM
SIBuddy
EG Swaps
Nov 22, 2005 12:41 AM
HondaCivic777
May 2, 2005 10:57 PM
