EK Swaps 1996-2000 Civics
B18c Swap
Old Feb 6, 2005 | 12:46 PM
DenkiEx's Avatar
Default B18c Swap
Question swaping b18c into a 96 civic coupe 2dr, is this a direct bolt on ive read back and forth as to how the swap is between direct bolt in too harness mods and rear mounted parts??? Honda swap guide said direct bolt but i figure id ask here get it from someone who has done it.
Old Feb 6, 2005 | 01:07 PM
sacicons's Avatar
Default RE: B18c Swap
i did it into my 95, which has almost the same bay as the 96. its not too hard at all. it requires mounts from a 99-00 si or integra (the front mount which also holds the AC pump should come from the si or a dual cam del sol.) and other than that, the wiring is kind of a pain, but other than that, its about as easy as a stock to stock engine change. good luck, and its well worth it.
Old Feb 6, 2005 | 03:17 PM
DenkiEx's Avatar
any advice you can give me as to wiring ,lol sorry if its asking allot just curious as what i have to look forward next month when it gets here
Old Feb 6, 2005 | 03:42 PM
DenkiEx's Avatar
by the way before i forget, before i order this i wanted to ask if ya know any solid places to get the swap from
Old Feb 6, 2005 | 11:31 PM
sacicons's Avatar
where ou located? kappa has a few places he suggests all the time, im sure he'll chime in. if youre in Nor-Cal, i could help you out, but otherwise, shipping is too much to do either of us any good.
Old Feb 7, 2005 | 08:20 AM
DenkiEx's Avatar
ya im upstate ny lmao, so a bit diff, hmmm but eh if your willing to help me in anyway be it info or what not or a point in the right direction thanks. but ya wish i was in north cali
Old Feb 7, 2005 | 06:42 PM
Kappa22's Avatar
Yeah, it's true. These are the places I give to everybody.
Sunrise JDM (They're in Quebec, so they might be close to you) http://www.sunrisejdmmotors.com/honda.php
Nippon Motors (SoCal, maybe not your best option). http://www.nippon-motors.com/honda.htm
Old Feb 7, 2005 | 10:50 PM
DenkiEx's Avatar
alright thanks for the sites. and how about an insight to adding a vtech pin on the harness and such. what you guys think the best way to do that is
Old Feb 7, 2005 | 10:55 PM
DenkiEx's Avatar
http://www.passwordjdm.com/product.a...For=&PT_ID=134 tell me what you think about this looked pretty solid but figured best bet is to ask on here
Old Feb 7, 2005 | 11:51 PM
sacicons's Avatar
go cut the harness out of a 6th gen civic at the pick-n-pull do it yourself junkyard in your area, then remove the pins and splice them in.
