engine swap
Hello everyone im new to the forum and i could use as much help as possible. Right now i have a 94 mitsu 3kgt however my first car was an accord and im looking to get a civic. Im lookin at the 96-00 bodystyle and swapping out the engine to either an integra gsr or ls engine(i have heard that the ls has a stronger block than the gsr). i also want to run it with forged internals, hardened block, turbo, spray, and hopefully if its possible to run it with a 6 speed tranny. Do you think this project is possible? anything i should know before i undertake? any general input you have? anything you have would be great?
RE: engine swap
Welcome.
i have heard that the ls has a stronger block than the gsr sounds like youve got a plan, but youve also got your work cut out for you. good luck, and let us know if we can help with anything. |
RE: engine swap
Thanx for the input. this is kinda comin outta nowhere but since the rsx-s has a 6 speed tranny, would i be able to bolt it onto the gsr engine? and how strong is it? what would i need to upgrade? i havent done any research on it, its just an idea i had.
RE: engine swap
you cant take other parts from other engine series a rsx 6spd will only work with k series moters, while a b series gsr, ls will only work with a 5 spd from another b series. you could get a very expensive six speed for a lot of money but 1 more gear isn't worth more than your car
