EK Swaps 1996-2000 Civics
mini me assistance
Old Aug 25, 2009 | 06:02 AM
kanarrjl's Avatar
Default mini me assistance
I'm very seriously thinking of doing a mini me swap I've got a y7 and want a y8 but am a little fuzzy on what I need. I know that I need a y8 head a v-tec solenoid and from what ive heard an ex ecu is there anything at all that I will need to complete this?
Old Aug 25, 2009 | 06:14 AM
y8 head
y8 intake manofold (dont have to but is a gain+)
y8 wire harness (you need the vtec plug and the oil pressure switch plug from it)
y8 dizzy 0bd2 96-00
96-97 ex ecu (vtec) or get a p28 ecu and a obd2a-obd1 jumper harness.
some extra wire
some extra ecu pins
knock sensor(not needed if coverted to obd1 with p28)
head gasket
intake manifold gasket
Old Aug 25, 2009 | 01:54 PM
kanarrjl's Avatar
k thanks
Old Aug 25, 2009 | 06:42 PM
hamorhead's Avatar
umm can he use the y7 dizzy?
Old Aug 25, 2009 | 07:13 PM
no a nonvtec dizzy's bolt holes dont match a vtec head.
Old Aug 26, 2009 | 05:20 AM
hamorhead's Avatar
thats what i thought but i didnt see that in your list
and OP while your at it you might as well do your timing belt and water pump
Old Aug 26, 2009 | 06:30 PM
kanarrjl's Avatar
ok will do, thanks, well ive started buying the stuff to do this i bought the ecu! is there a performance dizzy out there or something that would be an upgrade or just go with a stock one?
Old Aug 27, 2009 | 07:51 AM
hamorhead's Avatar
use the stock one
theyve been tested to about 500hp (i think) so you will have no problems
which ECU did you get OBD1 or 2? just curious
Old Aug 27, 2009 | 02:08 PM
kanarrjl's Avatar
p2p i think, its obd2 for a 00 ex
Old Aug 27, 2009 | 02:27 PM
99-00 is obd2b you have a obd2a 96-98
this is obd2a 96-98
and this is obd2b from 99-00
