EK Swaps 1996-2000 Civics
need help y7 to y8 swap
Old Oct 13, 2005 | 09:29 PM
RSXt3's Avatar
Default need help y7 to y8 swap
hey recently my timing belt stretched you know the outcome.
i had a d16y8.
i picked up a good d16y7 and good y8 head put them together w/ new gaskets i have only two problems.
one i have a wire on the back of the engine coming out of the harness w/ two other ones one is the crank pos. sensor its hooked up fine the other is the block temp sensor its hooke up fine. the one i cant figure out is a single red wire its pretty short the plug is round and has space for two prongs but its a single wire like i said.
the other is on the very top back of the intake mani. that sensor has a spot for a vaccuum line pointing straight down. i have the line it has a plastic piece on the end like it pops into a rubber fitting. cant figure out where.
also theres a tube running from the thermostat to the coolant pump theres a space on there for a line cant figure it out.
please help. need to get to work.
Old Nov 9, 2005 | 08:03 AM
Marty's Avatar
Default RE: need help y7 to y8 swap
it's a knock sensor, the Y7 block does not have a place for a knock sensor while the Y8 does. Just take the sensor out of your old block, hook it up, and fasten it to your firewall in a out of the way place
Old Dec 31, 2005 | 09:26 AM
HondaCivicRacer91's Avatar
Hey i was wonderin if you knew some sites where i can find a head because i am going to do a vtech head swap on my stalk honda civic Dx do you think going with a vtech is the best to go with for more power or do you recomend somthin else
Can you put a dual cam head on single over cam engine
Get back to me asson as possible
Old Dec 31, 2005 | 09:34 AM
silvercivicsrs's Avatar
you can check out houston imports.com some guy is selling his D16Z6 complete head for 120. or u can go ebay style like alot of people.
Old Dec 31, 2005 | 12:57 PM
Marty's Avatar
http://www.sohchonda.com/v-web/bulle...pic.php?t=8984
^ you have to register and log in to view
Comes complete with valve cover and i even have the intake manifold.
I just got a new JDM D15b, but am not using the head only the bottom end. These engines come with a garuntee that they only have 40k miles when you buy them, so the head is in prestine condition. Comes with cam, valve train, valve cover, vtec soleniod, and i even have the intake manifold with all hardware on it ready to rock.
200 shipped.
Rsporty
EG Swaps
Feb 7, 2010 06:01 PM
hydro_yang
Sep 12, 2009 01:18 PM
silvr63vet
Dec 4, 2006 03:55 PM
EKswapInfo
EK Swaps
Sep 26, 2006 05:33 PM
Jas10hon
Jul 4, 2005 10:35 PM
