02 si hp mods
Old Feb 27, 2007 | 01:56 AM
jewrrick's Avatar
Default RE: 02 si hp mods
thanks for all the feed back. I think im going to go for boost with upgraded internals. If you have suggestions please post em up.
Garrick
Old Feb 27, 2007 | 04:36 PM
Nail I3unny's Avatar
THE BEST thing you can do for that engine is get a K20A2 headswap off of an RSX-S
Old Feb 28, 2007 | 01:42 AM
jewrrick's Avatar
correct me if im wrong but don't i have the same motor as a RSX?
Old Feb 28, 2007 | 01:56 AM
blackmetal619's Avatar
ORIGINAL: jewrrick
K20A3 [ul][*]Found in: [ul][*]2002-2005 Honda Civic Si [ul][*]Displacement: 1998cc[*]Compression: 9.8:1[*]Power: 155hp* (119kW) @ 6500rpm[*]Torque: 139[/ul][*]2002-2006 Acura RSX [ul][*]Displacement: 1998cc[*]Compression: 9.8:1[*]Power: 155hp* (119kW) @ 6500rpm[*]Torque: 139ft·lbf* (191N·m) @ 4000rpm[*]Redline: 6800rpm[/ul][/ul][/ul]
Old Feb 28, 2007 | 08:03 AM
RSX is NOT the same as the RSX-S, which is what nail mentioned
Old Feb 28, 2007 | 01:23 PM
scottsilke's Avatar
I drive the 2006 Si with the K20 engine. With the weight difference between your car and mine;2553 lbs. vs 2881 lbs., will definately make your car a space craft. "make sure you upgrade your breaks first." --do you already have rear disc?
s
Old Mar 1, 2007 | 12:20 AM
kevin_02si's Avatar
did you decide on any mods? i need to try and keep up with my brother in laws built 93 civic b18c1 swap anyideas how to beat him.
Old Mar 1, 2007 | 01:32 AM
jewrrick's Avatar
well right now my plans are on hold until i get adjusted at my new job but i figure on turbo. and to scott yes i already have rear disks.
dalifts
Aug 25, 2007 12:03 AM
spevie
Oct 6, 2004 08:40 PM
telecasteriv
Sep 26, 2004 02:35 PM
kobejelbryant8
Aug 31, 2004 06:18 PM
NTX
Aug 3, 2004 05:02 AM
