4000rpm .. engine makes dead spaces or waters like i put neutral
I own a new Honda Civic sedan, 1400cc of 2005.
I have run 800km till now and i see something strange at my engine when i speed up with low gears. When i have put 2nd or 3rd gear and the engine runs at 4000rpm and up, i see that it makes something like "waters" or "spaces" the engine.. i feel it like i have put the Neutral for a couple seconds .. The same happend with 4th and 5th gear. Also i have seen that even if the road has a small percent of grade the engine loses a lot of its power. I say a lot of its power because i compare with my Toyota Corola Sedan 1300cc of 1994 car and it seems that it has a lot of much power from my new Honda Civic 1400cc of 2005 and it does not make this "dead spaces" as i feel them up from 4000rpm. I wonder if this happens because the engine is still new (800km). If someone know, please inform me because i already worry a much about this. Thanks guys.. |
RE: 4000rpm .. engine makes dead spaces or waters like i put neutral
It could be your catalytic converter. That'll happen sometimes when your cat is plugged up.....loss of power and sometimes stalls.
could be a bad sensor...might want to cheack those. my 02 when bad on my probe and could haardly move after a few rpm
nothing helpful 'till now :)
If it's an 05 take it to the dealer. If it isn't running right, they should make sure it does. I wouldn't be trying to troubleshoot a brand new car, I would expect Honda to do that.
pacman is correct, I missed the 2005 thing myself. Why aren't you taking it to the dealer?
i will
just asking if there are any known issues about that on new engines below 1000km at 05 civic. |
