95 ex engine swap
Old Dec 19, 2005 | 09:06 PM
bleedhondos's Avatar
Default 95 ex engine swap
i want to swap a auto to manual and b16A SiR II is this all i need.
motor, hydraulic tranny (s21, y21), ecu (p30), alternator, starter, clutch, flywheel, intake manifold, exhaust manifold, fuel rail, injectors, distributor, engine harness, axles with half shaft, shift linkage, stock motor mounts and also comes wiht all te sensors i needed. Do i need anything else?
Old Dec 19, 2005 | 09:08 PM
finalimpact's Avatar
Default RE: 95 ex engine swap
clutch pedal asembly, clutch master, clutch slave, tubing to run from clutch master to slave. what car is it going into? 92+ requires either replaceing the frame mounted tranny braket on the pass side or buying the 5spd conversion adapter from hasport.
Old Dec 19, 2005 | 09:27 PM
its going into a 95 ex. thanx
chbulldogs11@msn.com
May 27, 2011 09:05 PM
skibum853
Nov 18, 2007 09:40 AM
badboy4life
Sep 1, 2007 08:28 AM
Kingzlei
May 5, 2007 04:06 AM
silvr63vet
Dec 4, 2006 03:55 PM
