K24?
Old Dec 12, 2005 | 01:53 PM
icarus's Avatar
Default K24?
What would i need to fit in a k24 in a 94 ex ? most people that i asked for sugeestion on a potential engine swap suggested the rsx engine. Anyone ?
Old Dec 12, 2005 | 03:44 PM
ef4life's Avatar
Default RE: K24?
hasport mount kit, engine, trans, ecu, key engine harness, charging harness, custom axles( hasport) custom header (hasport), rsx or accord cable shifter, shift cables, new throttle cable, maybe more, thats all i can think of at the moment. The only problem with the k24 is the taller deck height which could cause hood clearance issues, and it has less power than the type s engine and doens't come with six gears. check www.hasport.com for more details on what you need
Old Dec 12, 2005 | 08:22 PM
Nail I3unny's Avatar
Default RE: K24?
have fun putting a K into an EG.
the best engine for an EG would be a GSR (b18c1) or an SIR-I (b16a1)
Old Dec 12, 2005 | 08:44 PM
ohbiskits's Avatar
Default RE: K24?
ORIGINAL: icarus
about 6000 bucks
Old Dec 12, 2005 | 09:08 PM
Default RE: K24?
more like 8 or 9. the engine itself is like 6k, then mounts, shift linkage, wiring, everything. K + EG != worth it
for those of you who dont know 1337, != means 'not equal to'
Old Dec 12, 2005 | 09:24 PM
Kappa22's Avatar
Default RE: K24?
Actually it's originally C or C++...
Old Dec 12, 2005 | 09:34 PM
Default RE: K24?
huh?
Old Dec 12, 2005 | 11:57 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: K24?
!= goooes waaay back even before C/C++ ...
Old Dec 13, 2005 | 02:19 AM
Kappa22's Avatar
Default RE: K24?
Well there ya go... I'm too young to know that. And I don't do programming.
Old Dec 16, 2005 | 01:39 PM
Marty's Avatar
Default RE: K24?
ORIGINAL: ohbiskits
ORIGINAL: icarus
about 6000 bucks
Not for the K24, you can pick up a K24 longblock for like $1000 to $1500
