99 civic hx timing issues
Old Oct 3, 2010 | 10:31 PM
wfrohwein's Avatar
Default 99 civic hx timing issues
Got my civic running finally after 2 years of sitting in the garage. Put a new fuel filter, spark plugs (oem honda), spark plug wires, cap, rotor, fully tank of fresh gas (91 octane) and cleaned the aem shortram intake filter with the k&n recharger kit.
All that, and it runs like hell. Hella sluggish starting off, no power. I borrowed a timing light from a buddy, set the cylinders to 4 on the timing light, put the clip on the cylinder 1 spark plug wire (facing correctly), started the car, let it run until the engine was at normal operating temperature, checking the timing and it was a 1 degree. I set the light to 14 degrees and staring to rotate the distributor to advance the timing. The highest i could get it is 3 degrees, the distributor will not rotate any further. It ran a bit better, but know this is not correct.
The idle is also low, registering at 600 rpm, i adjusted the idle screw by turning it counter clockwise, and the highest i could get the rpn is 650.
So my question is, what would cause the timing to be retarded so much? Only thing i can think of is the sensors in the distributor are reading incorrectly.
Here is what the car has:
dc 4-1 headers (ex)
aem shortram intake
5zigen catback (ex)
performance cat (you can see right through it)
stock p28 ecu
obd2 - obd1 conversion harness
The only things i have not done, is change injectors, check cylinder compression, checked cam to crank timing marks.
Thanks for any help.
Old Oct 4, 2010 | 02:13 PM
camiguel's Avatar
If your timing belt is off by one or 2 teeth it could cause this, so check that and that will most likely fix it.
Old Oct 5, 2010 | 07:44 AM
wfrohwein's Avatar
Default 2 teeth was the problem
Checked this morning. Can't believe i didn't check that -=/. It must have slipped when i first started it up after 2 years. Thanks for your help.
Old Oct 6, 2010 | 02:24 AM
camiguel's Avatar
No problem glad I could help.
Basil
13
Sep 10, 2007 07:57 PM
skibum853
Aug 31, 2007 12:06 PM
bw1339
Jan 25, 2007 09:30 PM
t34me
Nov 12, 2006 07:24 AM
Sharpshooter
Jan 6, 2005 07:07 PM
