Almost Completed The Motor
I have almost finished my motor, I still have to put in the camshafts and springs and retainers.. after that I would like to get it dynoed... I would like to be able to get above 160, does anyone think this setup is possible?
- Weisco High Compression Pistons 11:5:1 - Eagle Rods - Crower Stage 2 Camshafts - AEM Tuneable Cam Gears - Crower Titanium Valve Springs and Retainers - Skunk 2 Intake Manifold - Skunk 2 62mm Throttle Body - AEM Fuel Rail - AEM Fuel Pressure Regulator - DC Headers - No Cat - Test Pipe - APexi Muffler - AEM Full Cold Air Intake - Skunk 2 Short Shifter - MSD Ignnition - ACT Stage VI Clutch - 8 lb FlyWheel - Unorthodox Racin Pulley - AC/PS Removed |
RE: Almost Completed The Motor
if you mean 160 at the wheels i doubt it, probably 140-150 with all that
ad some spray, she can handle it no problem
are you staying n/a since you have some high compression pistons?
Whats with all the MSD? I thought stock dizzy can handle 400 hp
you certainly put some time, effort AND money into your motor.
schweet. |
All good parts except the MSD crap. Put stock igntion back on and you should make around 150-160. I would also consider using an Exedy Stage 1 clutch (that ACT will be STIFF), and a Quaife LSD (some people recommend OBX, even me before, but after reading around a bit I've decided doing it right the first timeis the way to go). Make sure you have a Z6 or Y8 transmission as well (Z6 preferably). Also, what are you using for tuning?
And just fyi, you have only one cam gear, one camshaft, and one header. |
