B16 swap HELP
Old Jul 18, 2007 | 04:59 PM
1c1v1c1's Avatar
Default B16 swap HELP
Okay i have a 1997 DX hatch...and i have a 96-97 JDM B16a swap....
Everything is hooked up exepted the exhaust, and one o2 sensor could either of the two be the reason my the car doesnt idle
cuz when you start the car it fires up then it just dies....the only way it runs is when u give it gas....so does anyone know what this could be...
THANKS
Old Jul 21, 2007 | 08:14 PM
johndoe123's Avatar
Default RE: B16 swap HELP
check out your map sensor
Old Jul 21, 2007 | 08:20 PM
ej6buddy's Avatar
try and rent a scanner from a parts place to check everything if you're throwing any codes. but a faulty o2 sensor will cause low idling and sometimes stalls out depending on the condition of the motor (or other sensors)
Old Jul 21, 2007 | 11:46 PM
BlackEM1's Avatar
Member
I would start checking outthe IACV and TPS sensors, you should be throwing a check engine light if they're acting up.
Old Jul 22, 2007 | 06:43 AM
Before you touch anything else, hook up the exhuast and o2 sensor. Why would you even bother running the car without that stuff?
It's most likely not the reason for your issue, but it's best to have everything assembled prior to trouble shooting.
thatguywithahonda
Jul 3, 2013 07:36 AM
turbo speeder
Jan 28, 2009 03:57 PM
Civic Si 00
Oct 29, 2007 11:39 PM
nexgen91
ED-EF Swaps
Mar 18, 2006 05:25 AM
outlawzz23
Aug 9, 2004 08:21 AM
