b16a2 head
wat heads can i use on a b16a2 short block besides the standard dohc vtec one??
RE: b16a2 head
B18c's
RE: b16a2 head
stick with the PR3 head that you have. The B16 head is the best flowing of the bunch and that is why they use it on the type r's also. So you pretty much have a Type R head w/o type r cams. If you want a killer upgrade get a set of CTR cams
RE: b16a2 head
^ are CTR cams better then lets say Skunk2 Stage 2?
RE: b16a2 head
I think they are better than anything junk2 makes. Really it depends on your application, the junk2 cams are more than likely going to run more duration and a slightly higher lift.
RE: b16a2 head
ORIGINAL: Marty stick with the PR3 head that you have. The B16 head is the best flowing of the bunch and that is why they use it on the type r's also. So you pretty much have a Type R head w/o type r cams. If you want a killer upgrade get a set of CTR cams |
