b16a2 head
Old Jul 16, 2007 | 10:45 PM
ranom01's Avatar
Default b16a2 head
wat heads can i use on a b16a2 short block besides the standard dohc vtec one??
Old Jul 17, 2007 | 07:47 AM
Lost's Avatar
Default RE: b16a2 head
B18c's
Old Jul 17, 2007 | 09:20 AM
Marty's Avatar
stick with the PR3 head that you have. The B16 head is the best flowing of the bunch and that is why they use it on the type r's also. So you pretty much have a Type R head w/o type r cams. If you want a killer upgrade get a set of CTR cams
Old Jul 17, 2007 | 10:08 AM
Lost's Avatar
^ are CTR cams better then lets say Skunk2 Stage 2?
Old Jul 17, 2007 | 01:11 PM
Marty's Avatar
I think they are better than anything junk2 makes. Really it depends on your application, the junk2 cams are more than likely going to run more duration and a slightly higher lift.
Old Jul 17, 2007 | 05:30 PM
BlackEM1's Avatar
Member
ORIGINAL: Marty
B16a2 and B18c1 heads flow almost identical through the RPM range. The differences are negligable.
Captain_Sl0w
Oct 4, 2008 03:05 AM
97civicturbo
Mar 14, 2006 12:07 AM
ScoobyAddict14
Mar 12, 2006 08:51 PM
hachi_roku
Oct 21, 2005 08:27 AM
civic96RB
Jul 3, 2005 01:54 PM
