b18 cam install
Old Apr 3, 2006 | 08:50 PM
sway2003's Avatar
Default b18 cam install
My buddy just bought a set of stage 1 cams for his LS non vtec integra, we are going to install the cams in a few days and wanted to know if anyone has a website that you know of that directs you step by step of upgraded cam install, i.e. timing adjustments, etc. any help would be appreciated, thanx
Old Apr 3, 2006 | 09:24 PM
hondajoe77's Avatar
Default RE: b18 cam install
You should get a Chilton's book from the part store it's in there dude $19.95 There the best repair manual with pics
Old Apr 3, 2006 | 09:29 PM
sway2003's Avatar
will it make a difference that the cams arent stock spec, so wont i have to adjust timing?
Old Apr 4, 2006 | 04:33 AM
Marty's Avatar
Anytime you take the timing belt off you need to adjust it after re-installing it. The cams will be a direct drop in, that is what is great about stg 1 cam/cams
Old Apr 5, 2006 | 08:45 AM
sway2003's Avatar
I knew you had to adjust the timing for the timing belt, I just didnt know if I had to retard the timing any more extensively, thanks marty
dustin_crxsi
Jan 26, 2007 12:59 PM
civicblend97
Apr 29, 2006 01:12 AM
Pete
Oct 13, 2005 11:32 PM
Dickie
Jan 16, 2005 05:56 PM
