b7 head with a y8 manifold????
i have a d15b7 and i got my y8 manifold yesterday and wanted to kno if its possible to swap it, i was thinking the map sensor would be diffrent. i was thinking i would get better breathing.
yes it will fit but did you get a manual im or a auto im?
i want to say m/t but how whould i be able to check. i kno the head it came off of was vtec.
does it have a iacv on the back side of the im?
post a pick of it and ill tel you |
i jus searched it. and its an auto. will this still work? what are the pros and cons of it not being manual?
I don't think 96-00 auto has an IACV, which is something you need. In otherwords, you need a manual transmission intake manifold.
no it doesnt have the iacv. so i might as well take it back.
Wait a sec. The IACV is on the TB on ALL 5th gens, isn't that right? (I might be wrong here, but if I remember correctly that is the case) So the manifold should be good.
no the automatics dont have it, only the manuals do. on the y8 intake manifold.
also when you put the y8 im on a obd1 car you have to convert the iacv, |
Not the point I'm trying to make. I am pretty sure that ALL 5th gens have the IACV on the TB. Is that not the case? (looking at pictures of a TB from a 94 dx auto and it is on the TB).
