Bigger fuel injectors, how big?
I was thinking in to buying some slightly bigger fuel injectors for my 93 civic. I just want some thing new, that will give me a little better throttle respone. I dont want to go too big, I just want the new injectors to compliment some of the other mods on my engine. What is the size of stock injectors on a 93 civic ex 1.6 in CC's? Also, how big should I go, and what brand?
Thanks!
Andrey
Thanks!
Andrey
Here's the list of the mods that will be on the engine by spring. Can you please tell me what size injectors, and what brand I should get.
AEM Cold Air Intake
Holley 68mm TB
Skunk2 Intake Manifold
MSD 8.5mm Super Conductor Spark Plug Wires
MSD Blaster 2 Coil, and MSD Super Cap
AEM or OBX Fuel Rail
Venom 400 Performance Control Module
DC Sports Ceramic Header
Zigen Stainless Steel Cat Back Exhaust
AEM or JDM Cam Gear
Increase Compression Ratio 10:1
AEM Cold Air Intake
Holley 68mm TB
AEM or JDM Cam Gear
thanks for the reply.
Would the prelude injectors fit right in to the AEM fuel rail for the 93 civic, and would they work with skunk2 intake manifold? In other words, would they just pop in and hook up with out any other mods?
Thanks a lot!
Andrey
Thanks a lot!
Andrey
im 95% sure they will. i know the mitsu injectors people use a lot, need a little bit of modification, but its nothing major. but yeah, for high compression NA, go with prelude injectors. but they have to be 97+ because you need saturated ones, not peak and hold.
